I've pulled so much great info off this site and haven't really contributed much. Most of the answers are here if you search hard enough but I found a really easy fix for a stripped oil drain plug that may help somebody. My drain plug was at the point where it would just get snug and then if you turned it slightly more it would spin. so I thought maybe I could get a similar drain plug from something else with slightly larger threads and tap my case to fit. I hit Auto Zone and looked through the replacement plugs until I found a contender. I put it in the case to check the size and pitch difference to see if I could tap it without drilling out more material. As I started screwing it in the original threads I realized it was really close yet snug after the first couple of threads so I went for it and just screwed it in to the case. I know it thats not how threads are made but this thing went in like a tap probably because the case is mag. The end result (besides immediately going to the track) was...
1. I didn't have to tap it.
2. It has a built in rubber O-ring that replaces the crush washer to seal
3. I've done around 10 oil changes and it is very solid permanent fix. You can torque it down to spec and all is good.
Never leaks****************************************
My bike is a 1980 390cr so there are a lot of years that this trick will work. The part is M14x1.5 pilot point with gasket. Here is a pic of the packaging. Dorman Part #65266.
