sticking front brake
big--d
the front wheel on my te 310 doesn't run freely, its sticking on the caliper and the front brake is spongey, ive taken the caliper apart and greased the pins fitted new pads even a new disk, then bled the brake. but its still the same, any ideas????
worn seals in the master cylinder? my old yz had terrible front brakes, really spongey. I put a seal kit in the master cylinder and the difference was incredible.
when you disassembled the caliper, did you take out the piston or just grease the slides? if you didn't check the piston seal it may be the problem also, especially with the brakes staying on.
good luck
joker
thanks joker, think ive found the problem tho took the caliper to bits again, and unscrewed the main slide pin and its slightly bent!!! god only knows how thats happened. ordered on up so will have to wait to see if it works.
Thats probably it! Also as joker said, the caliper piston seals and pistons themselves can cause sticking. Bad brake fluid can cause spongy-ness. Bad MC seals can cause spongy-ness.
