Steering Stem Bearings for a 1983 CR?
Discussion in 'Vintage/Left Kickers' started by VoodooHusky, Jun 8, 2019.
  1. VoodooHusky Husqvarna
    15 Miles North of Hangtown
    1983 Husqvarna 250 CR
    2018 Husqvarna FE 450
    Does anyone know the ID, OD and width for an 1983 250CR stem bearings? TIA
  2. fran...k. Husqvarna
    eastern ct
    It is a cone on the stem and a cup in the frame. There are numbers on the parts. The origionals are made in England and I believe inch series not metric. Sorry I can not tell you what you ask for at this time. It is the same tapered roller bearing assembly as in my current avatar bike. The seal probably is Husky specific if I recall. I guess the cone and cup could come as a set but that is not how I got them from the industrial or even NAPA.
    VoodooHusky likes this.
  3. Bryll Husqvarna
    Some
    Some
    Timken L44600L
  4. fran...k. Husqvarna
    eastern ct
  5. fran...k. Husqvarna
    eastern ct
    Oh there are various ways to modify things to work. If you get to mill like vertical Bridgeport for example and a boring head there is an air powered attachment that fits into the 5/8 hole on the boring head. In place of boring bar. clamp the cone or the cup and modify the bearing part. I used essentially dremmel sized grinding stone. These things are often kind of how bad do you want it.
  6. VoodooHusky Husqvarna
  7. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    download a parts manual from HVA factory and it should have the bearing numbers on the part for you
  8. VoodooHusky Husqvarna
    That was a good tip, thanks!
  9. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    also tells you how long each bolt is...which is great when they come back from the plater in a tub:eek:
