Squish band clearance
Discussion in 'Vintage/Left Kickers' started by toolie, Jun 11, 2019.
  1. toolie Husqvarna
    Ontario, Canada
    1986 400 XC, 2018 TE300
    1986 Can-am 250 ASE, 1985 RZ500
    How much squish band clearance is everyone running? I'm thinking about 1.0mm at say sea level is where it should be.
    What about head and base gaskets thickness stock? Any options?
    How about custom copper gaskets in different thicknesses.
    https://coppergaskets.us
  2. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    72 450cr 73 360rt 77 360auto 83 500x
    2x 75 DT400 80 KDX175 ZRX1100
    We're going to need the year make and model, also I don't think Husqvarnas use a head gasket unless their water cooled.
  3. toolie Husqvarna
    Ontario, Canada
    Hmmm....just below my avatar friend.
    86 400XC
  4. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Haha, sorry it did not correlate to my instinks. I only have ac models(except for street), but lots of these fellas have LC bikes. I had an 82 Honda 250r that required .7mm to keep the piston off the gasket I never figured out why til years later(circa 1993). To prevent the failure of their crappy gaskets, but I am sure the newer gaskets are superior. I put an old used copper gasket back into a 1955 Kohler Generator and it has been wonderful, albeit only a year or so with little usage. Check out my vids top see it in operation. One of my proudest builds. Good luck toolie! Chris
  5. Picklito Husqvarna
    Northern Kalifornia
    KTM 150xcw
    1.0mm is a good starting point. I have had Cometic make base gaskets in many thicknesses for the AC bikes.
  6. toolie Husqvarna
    Ontario, Canada
    Great, thanks.
    I'm not sure what current clearance is but I'd like to go in steps just to be on the safe side. The piston was replaced when I bought the bike and being an aftermarket piece it might be off. Just a feeling, compression seems a bit low.
  7. Picklito Husqvarna
    Northern Kalifornia
    KTM 150xcw
    It is probably about 1.5mm stock. But ya, go down in steps and see what you feel. Contact Chris Workman at Cometic.
