Speedo issue
CKPC
I know I have read some posts on speedo problems but not sure if this has been asked. My speedo is misreading my speed. Never had a problem until a couple weeks ago and it now seems to be showing at least double the speed I am traveling if that makes sense. (07 TE510)
Is there an easy fix or should I look at replacing it?
Everything else seems to be working fine.
Thx for any help anyone might have!
I know that has been discussed that the Stock computer is crap. The vibrations make it short out or something. After about 6months or riding my 07 TE450 it was pretty much dead. I replaced it with a Trailtech and like then new one MUCH better as it gives me engine temp readings + a whole lot more. There was a thread about how someone took it all apart and fixed it on TT somewhere... Can't seem to find it at the moment.
-Blake
Well you won't get any speeding tickets at least. :thumbsup:
Personally I'd check the connections, then when it is acting up whack it & wiggle wires to see if there are any changes to the symptoms. Something is loose and the only question is inside or outside the box.
Are you sure it's OK to use phrases like "whack it" in the technical sections. Are there no standards here???:lol:
Just purchased a Trail-tech, all plastic brackets,and light are broken on the stock speedo. Almost 400hrs. Does anybody know if the trail tech has an Hr meter built in? And if so can I input the orig. hrs into the new computer.
also have you tried reseting it by unplugging your battery for 15 minutes or so ???.. My dash acts funny about every 5-6 months. resetting it always cures it so it doesnt bother me that much.
