Anyone have a source for aftermarket replacement radiators for a 2006 TE610? Mine are bent, but don't leak. Just trying to source a spare set to throw in the trailer for extra insurance...
I had a leak in mine, it took 3-4 weeks to get. Parts are getting harder to find and source. It was ordered from Halls Cycle.
Give us a call, we should be able to have a pair of heavy duty, extra-capacity supercooler radiators for you in a couple of weeks for right around $325.
TE630 are the same - Chinese do them and they are fantastic!!! http://www.ebay.com.au/itm/GPI-ALUM...486983?hash=item43c9905047:g:VVAAAOxyYANTb1sf Stu
Are you sure the 630 radiators fit? They are not the same part number as the ones for the 610. It appears that the small tube that connects to the overflow bottle doesn't exit the radiator mouth in the same direction and it doesn't appear that the lower connections exit at the same angle as the 610 radiators from looking at the pictures.
Hi - did you sort out your radiator issue? I have an SM 610 2008 and the right radiator is leaking. I can see the Chinese 630 radiators on eBay - did you get them and did they fit OK? Thanks, David
