Hi guys, I have problem... After I turned the ingnition this morning on, the green light in the left upper corner (for the headlight) went on, but just for a second. The Husky just stand there, I stood byside it and plugged the key in and turned it. So it's nearly immpossible that this issue caused by a cable. Then the speedo never turned back on. My last ride was two days ago and I noticed or did nothing what could damage something. And only the speedo is no not working, the rest is fine. I wonder? Does the speedo has internal fuses?
This has happened to me as well just change the fuse under the seat on the fuse plate. Not exactly sure which fuse it is, but I know its a 20amp yellow one. Check the schematics in the service manual to be sure.
