ascribner
I will share my project (pain and frustration and momentary speckles of joy) as I progress through building a dual carbon exhaust setup for my SMR511. Keep in mind, I am working out of my garage and have no access to any fancy machines. A miter saw, bench grinder, normal rotary cutting tools, a tig welder (not in my garage, at my cousin's shop), and a little bit of imagination are the only things at my disposal.
I knew well in advance of purchasing this bike, that a dual exhaust would be a project. All motards should have dual IMO -- just my opinion.
The first part was figuring out how to mount the duals to the subframe. Mounting directly to the subframe would not give the needed clearance (and even with the aluminium spacers I installed, the fit is still a lot tighter than I would like. So after a bit of searching for aluminum, I found some spacers that would work. I welded the tabs to both sides Then test fit the mufflers (I am using different mufflers from what is pictured).
Now with the exhaust mounted, I have to figure out how to route my piping. This is the pipe I currently have.
Without, ready access to a heliarch machine, I busted out my hillbilly "engineering" imagination and figured out how to mock up the mounting (since I cannot find a pipe expander that will handle 1.5 OD pipe) -- using a pool noodle! So the pipes are rough length and overcut. Once I start to TIG it, I will have to clean up the ends and cut to exact length. I should have access to a heliarch machine tomorrow and will hopefully have it done.
Well, these exhausts are way too long. So off to the saw I go.
Now that everything is all cut and mounted, time to start the welding. First piece is the splitter.
All tacked up.
All tacked up.
