Hi So 1 of my magnets on the flywheel came loose. How can I fix this or where would I get parts for this. The small pieces on the side broke off can I just stick it back
I glued mine back using chester metal, strong two compound epoxy, some small pieces of magnets are missing but all works so far There is other thread on supermotojunkie http://supermotojunkie.com/showthread.php?148941-06-sm610-flywheel-stator-magnets about using replacement stator from electrexworld but I found it too complicated to attatch back metal piece to stator
I saw that post on smj but it doesnt looks like the guy got his to start, so im a bit scared to buy that flywheel and then it doesnt work. had a look this weekend the magnet is broken to bad and wont be able to replace it.
I replaced mine with the one from electrexworld. The magnets on it are internal so you never have to worry about them coming loose again. Changing over the backplate isn't too bad it's pretty much bolt off bolt on. Needed a new pick u coil on mine as well cuz the magnet had damaged it.
Thanks, I will need to check what ignition mine is using, will most likely be the same as the 2006 model
hi, I'm new here. I have a sm 610s ( from 2000 ) and I have a similar problem. I changed the flywheel (with a RO610) and the stator+pickup coil ( a good one from an another bike ). But it doesn't start. It starts only with a bump start ( once I started, it works fine until I will shut it off ). Do you have any advice ? I apologize for any grammar mistakes. Thanks.
Hi, The stator is in the correct position. From what i read there is the possibility that the pickup coil to not be compatible with the flywheel. TRUE or FALSE?
I don't know although I have heard of the pick up coil casing cracking, mine was damaged when my magnet came off the flywheel and I had to replace it. Search the forum there should be a list of ohm values etc for the stator wires.
Hi, Problem solved. I managed to acquire a flywheel with exposed magnets ( like the original one ). Now the bike starts, but with the new electrex flywheel it don't starts. Do you have any idea how to fix this electrex flywheel problem, because I don't know how long this old flywheel will work. I apologize for any grammar mistakes.
I don't know. When I got the electric flywheel I fitted it with a new pick up coil and the old stator and it worked fine.
