Ever since I replaced the master cap and clutch cover with 7602's (which are really sweet by the way) I have been leaking motor oil out of the bottom of the clutch cover and mineral oil out of the top of the master cap. Do I just need new seals, and if so, can I order them through 7603, or where do I get them? Thanks, Blake
BCVisin, You might try taking the covers off and making sure the oring and diaphram on the clutch are installed ok. Sounds like most likely the clutch is misaligned and the o ring on the clutch cover might be pinched or twisted. Give your dealer a call if you want to replace those gaskets. Let me know what you find. Later Clay
I have both and havent had a leak either. When i replaced them, i cleaned the rubber gaskets and made sure the engine srface was clean
Ya, I'm not sure what the issue was. I did clean it well, but when I took it apart, there was a bit of dirt, so I really cleaned everything off and used gasket maker. It was a really slow leak, nothing major.
