Factory fan has failed. Thinking of adding one to both radiators and adding a switch that will allow me to turn them on manually when riding some tighter single track. Anyone have any ideas on a good aftermarket fan option that would make a good solution?
https://www.trailtech.net/fan-kits I mounted one of their TTO water temp gauges in the cylinder head outlet hoses to monitor motor temp. Also installed a led idiot light telling me when the fan is on. The stock fan and rads seemed to keep everything within range even with the big Safari tank mounted, although the fan does seem to cycle frequently. When I looked at installing dual fans there is only room for 1 stock pull fan and then on the other would have to be a push fan mounted on the wheel side of the rad and am not sure of the room from the fender. The KTM 690 and 990 boys seem to use computer fans and custom mounts to dual mount the fans. Lots of threads over on ADV rider. I may have a 610 fan in my spares if no other easy options. Kirk
