Rekluse clutch
Bisho
I recently fitted the rekluse clutch to my '07 TE510, reduced engine braking significantly I would estimate I use about 30% less enfergy now, usually I am nackered after 4 hrs but felt great first ride and reckon I could go for another 2. Just a tip to avoid crashing when going over logs with the rekluse be very careful on the throttle my first go sent me over into a tree as you cannot pull the clutch in to stop on top of the log!
Anyway what I was wondering does anyone know where I can get a rear brake set up for my handle bar as the clutch lever is now defunct and it would be super handy for rear breaking in to right corners where I want to put my foot out or down.
Rekluse makes kits for LHRB, so you could probably get one where you got the clutch. I don't think there is a kit made that allows you to keep your foot brake though, you will probably have to go cold turkey. The master cylinders changed in 08 (I think) and kits are available that will retain the pedal.
