Rear suspension maintenance on a 2006 TE250
Discussion in 'Technical Reference' started by Coffee, Jan 20, 2009.
  1. Coffee CH Owner
    GO HERE TO DISCUSS THIS THREAD:
    http://www.cafehusky.com/threads/rear-suspension-maintenance-on-a-2006-te250.2161/#post-33503
    Remove brake from swing arm, note one is a sheet metal screw and another is a bolt
    Support brake
    Remove brake pedal
    Remove cover, kickstand, and roller from left side
    Pic says it all
    Glad I did the suspension that bolt was a bit dry
    All clean, bolt on left needs washer (not shown).
    There is a bushing with shoulder in swing arm, then washer, then nut all under the plastic covers
    These grease fittings are nice but not complete - I would not rely on the grease fittings greasing everything.
    Also the file "2006-DOHC-Husky-parts.pdf" is different than what this TE250 had. Here is a nice feature:
