Hi guys, I have a set of your rad guards on a 2000 te610 and they are awesome. I just got a 2000 wr360 that doesn't have guards and i'm wondering if the ones from the te will fit? I'm hoping you can save me the hastle of tearing the bikes apart for no reason.
Thanks for your business. Your 610 braces will fit the radiators on the 360 but the mounting to the frame is different. There is a large cutout for a mounting post on the 610. The 360 doesn't have the post and so the braces will be loose on the frame. They will fit, but it will be sloppy. With a little fabricating skills you should be able to come up with a solution. Clay
Thanks for the info Clay. Do you make guards better suited to the 360? I'd rather buy a new set if you do.
We do make 2 stroke specific guards. We are out of stock right now but should have the aluminum color in stock in a week or so. The red 2 weeks later.
