A few race gas questions for you guys and gals. All based on VP U4.2 fuel BTW. Also, note that I live in Alberta Canada where we have VP race fuel and 91 octane pump gas to choose from, nothing else available.
- is it worth it to run race gas at all? At $120 for a 20l can, it's pretty pricey, roughly 5 times more expensive than pump gas.
- Will the FI system on my 2008 SMR450 with power-up kit installed automatically compensate for the different (better) fuel compared to pump gas?
- Would you mix the race gas with pump gas or just run it straight? It's so expensive, I'm not sure I want to run it straight for day to day use in the SMR but have no problem using it in the TC250 since it doesn't get ridden as much
- What performance gain can you expect running race gas compared to 91 octane pump gas?
- Would you run race gas in TC250 for break-in?
- What jetting would you recommend for a TC250 at roughly 4,000ft elevation?
- What is the shelf life of race gas, how long can an open can be stored before it goes bad?
- Do you need to drain the tank and carb after using race gas if the bike will sit for a couple of weeks before it's next use?
