Bill: I recently purchased a TXC injector and ECU from BMP for my 2012 TE310. I've got the injector installed. I spoke with Bryon yesterday and bought one of the ZipTy fuel tank elbows. As soon as it is here, I will pull the tank and swap out the ECU. I've also got iBeat software and a cable coming from SEMCO. My question is, other than resetting the TPS after swapping out the ECU, is there anything else BMP does with regard to iBeat settings, or is the TXC ECU already good to go as is? If you change the settings, would you be willing to share? Thanks, Mike
Im running Pro Circuit T4GP Lowboy ex. and settings are 105/105/108 seems to run great here and over in the desert>200 ft to 3500 ft at temps from 85 down to 28 .Been working great for me.billf
This may be a dumb question, but when using iBeat do the larger numbers mean richer mixture or leaner mixture?
This is the planet Earth everything runs on oxygen,most of the time just Shell super and race gas chaser now and then cant tell alot of difference we add a bit of 2 stoke oil too our gas alot of times and K100 for bikes on the floor to keep it fresh.
My challenge up here in Alaska is that highest octane we can get at the pump is 90 (R+M/2), which is probably about 95 RON. The upside is this is pure non-oxygenated gasoline with no ethanol. The Husky manual calls for 96 RON. I can buy Sunoco 104 octane racing gas, but it is 4.5% oxygenated and 13% ethanol. Wondering which is the lesser of two evils: 1 octane number lower than the manual recommends, or a fuel that is 13% ethanol.
I recently started mixing 1/2 non ethanol premium (94 octane?) with 1/2 Aviation gas (100+?) after trying some that Walt mixed up in my two strokes.
Considered that, as we certainly have a lot of it up here, however 100LL avgas actually has quite a bit of lead in it. You wouldn't believe the amount of lead in the combustion chambers when the tear down an aircraft engine for overhaul.
Sorry to be a pest, but what mix ratio are you using when you add the 2-cycle oil? I'm thinking with the rpm the engine is capable of it would be nice to have a little extra lube for the valves and probably be good for the fuel pump and injector as well. Thanks.
We mix about 100-1,Spectro 3815 full synthetic anything but bean oil ,it gets gummy and seen it stick valves after sitting.we add the oil to keep a barrier between any ethanol or whatever else gas has in it now.It really helps keep corrosion between float needles and seats down and FI bikes hurts nothing just keeps a bit of lube on everything.
I was pointed over to this thread so it's revival time. I have the iBeat now and started playing with it a bit with mixed results. The baseline settings were 100/100/100. I have the TXC ECU, 12 hole injector, uncorked airbox and full FMF exhaust. Factory 4.1 rct. No O2 sensor with the resistor installed. I tried bumping up the low CO to 105 and I had a very rough idle so I lowered it down to 102 then to 101. It was around 50 degrees when I tried raising the CO so maybe that explains the rough idle? The TPS looks spot on. I use 93 octane pump gas with ethanol and 100 octane unleaded race gas with OK results. I can't figure out why raising the CO at low throttle has such a negative result. Any thoughts?
I think the TSC ECU and 12 pt is okay at around 100...at least that is what I gather form this site. Raising the CO at idle for you must simply make the idle too rich. I get a little "8 stroking" with mine at higher idle COs....and I even still have the 4pt injector.
