arbortodd2
Have never been able to kick start my 83 xc250 in gear with the clutch pulled in. Will only start in neutral. Any ideas on what the issue could be?
Period correct Magura perch and lever, but I don’t believe it’s stock. Dogleg lever, with the non-painted single piece perch. I do use the clutch while riding to keep rpms up. The clutch itself seems to work fine so far as normal shifting and keeping it on the pipe.Stock magura lever and perch ?
Just measured the clutch stack with the clutch still on the bike. The fiber plates are 3.5 mm plus, which is within spec. However the overall stack is 29 mm. I believe this is 2-3mm shy of spec which would indicate the metal plates are the culprit. I will order the steel plates and install. Probably will just replace fiber plates too while the clutch is apart. Hopefully this will fix the issue. I have the dog leg lever on the bike with the one piece Magura aluminum perch. Can I assume the black coated split perch is stock? I wouldn’t think the perch would matter all that much since the levers have full movement. Thanks Marty and to all who gave advice. I’ll post again once the clutch has been rebuilt and report the results. Ordered the disks from Phil at husqvarna-parts.com.Change the clutch lever to the Magura dog leg style like original, Make sure your cable is lubed good and is not kinked or tied down super tight to the frame. Change the aluminum disks in the clutch to steel and adjust the clutch assembly as per the manual. And finally use Torco MTF-L 75W oil. I have no problem starting any of my Huskys in gear.
Marty
Marty
Even the AUTOs Marty?![]()
Hahahahha, Just Jamming you Marty!! I was in St Regis MT 2 weeks ago, just a little too far for a visit! Next Year, MT, YOU and Santa Barbara CA to get some tools. Hope all is well with you and yours!! Chris
Andy, I was able to watch the clutch vids from HVA before installing the new disks. The info was helpful. Thanks.Watch the Clutch Videos on YouTube from Hva-factory!!!
Andy
