Peek Main Bearing Cage?
Wildebeest90210
Anybody had any experience with these. The cage is made from a plastic called PEEK which is rated up to 250degrees cent with short bursts up to 310degrees cent. Are they OK to run in a fuel/oil combo? Its the R/H main form an a/c 430.
It would appear to me from disassembling 1988 430 engines that is virtually what they used in them. That would lead me to tell you not to worry about the fuel issues. What you are showing is a normal 3205 or for some reason 5205 seems the same. Your bike would have come with an M series which is a maximum capacity bearing. Those bikes would have 14 balls per race and a loading slot to get them in there. I used an MRC one with a more reliable cage but only 13 balls (per row it is a double row) in mine. I use an electric heat gun to put the engines together and it may take me a few tries before I am happy with the placement of that bearing (how deep in the case) so I wouldn't use it. In some ways they improved the 87-88 and in some ways they got more economy minded.
Fran
Looked out the old one. More balls, always a good thing in any circumstance, will be revisiting my supplier.
