Opinion? Oil type and weight
20-50 semi-synthetic Spectro "Off Road" for a bike that's broken in.
This is what my dealer (George Erl @ Uptite Husqvarna) recommends and sells. Considering you're in CA the grades should be fine as the weather is generally warmer.
If Jeff or anyone at Tasky's tells you what to run in the bike then don't sweat it. 10-60, 20-50 whatever. He probably has you running the Motorex stuff, right? Good oil. Spectro is good too. Castrol is good. Mobile is good. Amsoil is good. Get a viscosity as close to recommended as you can find and afford and change the stuff every once in a while unless you are really wringing the bike out every time you ride. More often if that be the case. Just ANOTHER oil thread opinion.
