oil leaking from Gearbox sprocket shaft on '76 CR360 - WHY?
Discussion in 'Vintage Restoration Projects' started by Laverdaton, Jun 1, 2018.
  1. Laverdaton Husqvarna
    I thought the oil leak was coming from the seal and/ or gasket on the Output shaft, the oil leak is coming through splines of the output shaft...........I changed the seal and gasket - no difference. I've looked in the parts manual and I can't see why this should leak oil. The engine isn't overfilled - up to the level plug on the clutch cover and the engine breather on the same clutch cover isn't blocked......anybody have any ideas as to why?..........
  2. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    It leaks because 'Husqvarna' is Swedish for 'Harley-Davidson?'
    2premo and markt2 like this.
  3. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Nature of the beast.
    Always lean them slightly to the left.
  4. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    Stuck in the 80's vintage
    If you lean them toward the kick stand side, the shift shaft will leak LESS than the countershaft side.... :banana:
    ajcmbrown, Picklito and 2premo like this.
  5. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    There is no seal . The only thing that stops the oil coming out is the interference between the shaft and the bearing . The bearing is sealed tho .
    Can lessen it by sealing the spacer to the shaft and the inner bearing race
  6. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    HVA Factory do a kit to sort this problem. The only trouble is that I'm not sure if it fits the earlier bikes. Ping an email off to Andy and ask.
  7. Laverdaton Husqvarna
    ok thanks for your words of advice............
  8. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    I think Andy's kit only works on 1980 and up as the 1979 and lower countershaft is smaller than the 1980 countershaft. On the 1980 250CR I did last September, I over cooked the seal in the bearing and found that the seal could be replaced in the bearing without replacing the bearing. You can check with a bearing house or get one from Phillip like I did. Also Andy's kit is only for the models with non sealed countershaft bearings.
