Oil Leaking from Drive Sprocket
mattd676
Hi, I have an 09 te510. Noticed oil leaking from the drive sprocket (front sprocket shaft). Anyone know if this is an expensive fix or just a new seal?
After some mud rides, if that area gets caked in mud, my 08 TXC250 will leak there ... Cleaning that seal in the same fashion as a fork seal can stop the leaking or at least it always has for me ...
Should be a simple fix if you have to replace the seal but if I changed mine every time it leaked from mud, I'd be crying the bike is the problem when it is only dirt in the seal ...
