Neutral hard to engage; gear shift difficult with bike stationary
cjard
My TE310 seems to have quite a significant amount of clutch drag which i think is what is making the gears hard to engage when still. Engine off, no probs, bike moving, no probs, but nigh impossible to get neutral when engine running and bike stationary because of the pressure needed on the shifter. Problem occurs when warm or cold
Where should I start looking first? Clutch bleeding? Basket notching? Somewhere else...
thanks guys
Oil age, level and viscosity? My TE250 gets really notchy and hard to find neutral when the oil is getting old and/or low. I've also found certain brands of oil are worse than others, but that's all I'll say at the risk of starting an oil thread :D
Bleeding the clutch can't hurt either..
My 2010 TXC 250 will not find neutral while running. Fine when stopped and it will sure as heck find it while moving if I'm in an awkward situation! lol. I've just learned to live with it, but it can be irritating if you want to push or pull your bike since you pretty much have to turn it off.
I found this article a while back, but haven't gotten a chance to check it out on my bike.
http://www.cafehusky.com/threads/neutral-issues.14817/#post-133511
