Trenchcoat85
a few hints, mini- and micro-projects I did to my '14 TE310R; but not 310 specific I guess.
I consider these projects 5 minute quickies to 30 minute mini's. They're easy to do and (usually) don't take any special tools or parts. Let's begin:
Hose Clamps:
A lot of people like the Euro-style hose clamps. The biggest advantage I think is that you can use a phillips screwdriver, straight blade screwdriver or a 7mm socket (meh- a pain) to tighten 'em. Another purported advantage is that there are no exposed threads, so soft silicone radiator hoses don't get pushed through and possibly cut on the edges (I'm not so sure that this is a big problem). However, by switching to American hose clamps you get2 3 advantages: the hose clamps themselves are wider, spreading the forces out some, [edit] the clamps have less of a tendency to loosen than the euro-style, and (here's the big one): you can use an 8mm nut driver to tighten 'em. Now, I've been using a nutdriver for all the 8mm bolts on my Husky (and that's 90% of 'em, including the cases- thank you Italians for not going with the KTM-esque 6mm heads) for a long time. It's way-way handier than a T-wrench, and the driver handle keeps you from going insane on the torque. Since I have an 8mm nutdriver in my hand, almost always when I'm around the bike- this mod makes maintenance even easier.
Skid Plate:
I have an EE aluminum skid plate.... waiting to be mounted. I can't use it until I re-route my oil return line (sheesh). In the meantime, I am on my 3rd stock skidplate ($11 each- NBFD); they work okay. A couple of problems show up though: the side protection is too flexible and eventually gets pushed into the bolts holding the oil filter cover on. I added a piece of an old skid plate to the new one with Gorilla Glue (I don't know if it's ABS or PE but it's holding either way).
The other problem is that some people have had the external oil line broken (presumably by a branch or something). I decided to add a 2" extension, cut from the other skid plates, to help deflect branches in the most critical area. 2 other things: note the bolt retainer holding the mounting bolt; also I drilled a small weep-hole under directly under the oil filter cover (hopefully I'll spot a leak sooner)
mounted view- not too bad (I'll paint the hardware black so it blends a bit). I'll come back for a longevity report:
Hose Clamps:
Skid Plate:
