HI, picked mine up last Friday and managed to get a couple hundred miles this weekend.So far its great, but I have yet to see a maintenance schedule.Anyone has access to one that would be willing to post it? Here is a pic from this past weekend
600 mile oil change and usual hardware check. My bike going to dealer today who offered to do the service free, I supply the oil so he can make sure he puts together "oil change kits" for his customers and stock. Will get that together and post along with scheduled service intervals. BMW is every 6k. Should be close to the same. Dealer and I were talking to see if the filter, same as for the BMW , will be cheaper through Husky or the same etc. Will post as well.
The owners manual calls out the typical BMW schedule, 600mi first service, then 6000, 12000, 18000 ... Or 1k, 10k, 20k, 30k in kilometers.
What is required at every 6,000 miles? If valve inspections, how difficult is it accessing the valves and performing this service? When is the timing chain replacement? It would help if someone could post the maintenance schedule "table" that summarizes the requirements. Perhaps from the BMW G650GS since the TR650 does not appear available.
The owners manual only states the intervals. It's useless. :-) I'm looking forward to obtaining a service manual. Assuming similar if not identical work as the BMW version of the engine, every 6k mi / 10k km: - oil change - valve inspect/adjust - check things like clutch cable, brakes, torque a few key fasteners, check steering head bearings - hook it up to the bmw computer and check faults, reset service indicator In addition, at 12k mi / 20k km: - replace spark plugs, air filters In addition, at 24kmi / 40k km: - replace fuel filter After first year, and then every two years replace brake fluid BMW does not state an interval for the timing change.
I have already purchased 2 qts of the recommended castrol.Will the BMW filter work.Can anyone confirm this.For now the closest Husky dealer is 200 miles away....however the local BMW shop is picking up the Husky line,but probably not before I need that filter.
Interesting. I did a web search for 'bmw 650GS service manual' and I came up with a link to a owners manual here: http://www.bmw-motorrad.ca/bikes/G650GS If that is the same motor & transmission, that means the gear ratio spread is almost exactly 3.14. Pi That means whatever speed the bike does at X rpm in first gear, the bike will go 3.14 faster in top gear at the same X rpm... if true, that would be outstanding!
They are the same across the board. I put together the attached pdf showing gearing and speed (MPH) @ RPM. It looks right, I'll test it against reality next time I'm out.
For playing around with gearing I always use http://www.gearingcommander.com/ (choose BMW G650GS and play with sprockets ! )
Which model/year is the DVD capture from? The gearing site is nice, I never thought to search, I've seen similar sites aimed at bicycles. My calculations were more or less identical, but this page is nice for playing around with options.
You're right - its for F800GS, my bad. Maybe its better be removed... I found this http://www.bmw-motorrad.ca/pdfs/maintenance/G650GS.pdf which confirms your summary.
Yep same filter as the 650GS, i don't believe it's actually changed since my earlier Rotax's. Back in late 80's my first Aprilia based Rotax used the same filter too.
