Leaking drain plug.
skywalker951
After my last oil change on my 510 it has started leaking oil at the bottom drain plug. I tightened it some and this did not stop. Any ideas? New crush washer?
Might have to dump the oil again and make sure all is clean.(Bottom of engine)
You should not need a new washer...but you should make sure...it's there.
I don't even use my drain plug any more.:D
Just pull the S Steel filters out and all the oil will come out though the two side ports.:thumbsup:
Good advice. I won't name names, but when someone changed the oil in her 610 for the first time and then threw the washer out with the old oil...well, the driveway and the garage were a mess afterwards :bonk:
WoodsChick
