AbnMike
So as some of you know I just got a completely rebuilt/restored 83 250 WR (thread a few threads below). Not sure when it was restored but it was probably a few years ago, and then put away. Took some carb cleaning to get it running, ran it around the block and then put it up on the stand.
I was gone a week and came back and the pan below the stand had quite a bit of oil from the cases on it. I didn't notice it until I got it off the stand so couldn't tell you if it was leaning left or right (due to that bottom bracket thing). I didn't see where it was leaking but there is a solid plug in the bottom of the case on the oil fill side (left side). Is that normal? It doesn't look removable. I was thinking that may be the culprit?
It also may have leaked out of the oil fill. I didn't check when I got it if it was tight or not. It has sat now for 2 days without leaking (I left it one day leaning right and the other leaning left). The oil level looks to be correct now (for whatever that's worth).
The case bolts all were tight, the gasket is in place and is clearly new.
Second question - in the pic I'm attaching there was a ton of black oil all over the left side rear shock (clearly 2 stroke blow by) that I didn't notice after riding. It was so much I thought I'd blown a shock (I have no idea what is in these shocks, this is my first vintage Husky). I removed the shock and cleaned it up and saw more blow by behind it --- coming from where the pipe meets that rear muffler thing with the Ohlins sticker on it. I'm guessing that I just blew a bunch out since it had been sitting so long? There doesn't seem to be any clamp (well there is not a clamp, doesn't seem that there should be) and it's just in there compression fitting?
