Installing a headlight on a 2010 TXC 450
esweetland
I am looking to buy a 2010 TXC 450 and would like to install a headlight and taillight on the bike.
Does the TXC have a lighting coil?
Can I install a TE headlight on the bike?
I installed a headlight, taillight, and turn signals on my husband's 09 TXC. Here's what you need:
Headlight (Trailtech X2 for ours)
Wiring of various colors (don't bother with the cheap stuff from Ace...it just breaks)
Wiring diagram (in your manual) for your bike. I also obtained a wiring diagram for a TE to use as a template.
Taillight (DRC Edge II for us)
Rear brake actuation switch (can be purchased at Rocky Mountain for cheap - Tusk brand works well)
Electrical connectors - will vary depending on the headlight
I went with LED everything (except headlight) to keep the load low and haven't had any problems with anything. The stock stator seems to handle the load fine. Under the tank is a mysterious plug that goes to nowhere that has positive and ground that you can work off of. On my husband's, I also installed a handlebar switch (Tusk) for the turn signals and high/low/off for headlight. The turn signals will also require a turn signal relay (once again, Tusk sells one), but I think the turn signals were a waste of time as they got broken by trail obstacles. I also put on a horn.
Of course, this was on a carbuerated 09 so I didn't have to worry about any EFI stuff. Wiring may be completely different on a 10 also.
Unfortunately, none of this is plug and play and it took a lot of work between finding the right combination of parts and creating the added wiring harness with connectors. In hindsight, I wish we had just gotten a TE with everything all street legal.
