Installed FMF PowerCore 4 Exhaust But...
Savannan
Just received my FMF PC4 exhaust but I noticed that the stock husky exhaust clamp is too large. Went to the local auto parts shop and the guy told me just to use a automotive exhaust clamp...I guess you could if your hillbilly Joe(no offence to Hillbilly Joe, if there is one on here..lol :D)
What size do I need and what are those fancy clamps called?
Thanks
Sav
I just used high temp silicone, bolted it in place, let it set for 24'hrs. That is the instructions, that came with mine.
The FMF with map 3 (open exhaust map) really make her rip, though it's quite abit louder.
My FMF fit horribly. It was almost to the point that I had to call them and send another. Didn't want to wait though. I had to heat and bend the elbow supplied to a wider angle. Then I used a hack saw and sliced into the pipe so I could get more clamping power on the front of the elbow. I put a little high temp silicon on the pipe coming off the bike and then weaved some fiberglass strands into it to help fill the gap and then another gob of silicone to clean up the connection. I let it set up and rode it the next day with a huge fricken grin on my face. Did the jumper plug at the same time. It's really hard to believe what a monster the bike is after such a minimal mod.
I remember when some of us in high school would buy performance parts for our V8 cars and get minimal performance results out of each one. First came the glass packs and headers. Then a four barrel carb and manifold. After that, a good ignition system or a cam. As a package it was pretty good, but it wasn't until you pulled the whole motor and added higher compression pistons and heads with bigger valves that you truely got the power you were craving. All I needed on my 511 was a little jumper plug and a pipe....crazy!
I thought the same, except by loosening the header, for fitment it all went together. If you have not had it remapped
to map3 (open exhaust map) it will really make a difference. Only $40. I have been riding it like that and love that
set up. I am waiting for delivery of the PCV so I can try to have a docile tractor on technical stuff, and more of a ripper
Everywhere else. I smile at your talking about how the bike woke up, I remember being mildly amazed, and pleased
Because it ran like I had hoped. Enjoy and be safe.
Check out my thread from last year regarding new fmf install. It details the installation issue I had and gives a clamp part number.
