Can some one tell me where i can find and if it exists, the kit of gasket for husvarna sms 630 2011…or compatible gaskets from other engines…ebay is only 630/610 until 2008 Because i opened all the entire engine(hard find if neutral, and a damage on bottom of cranckshaft) and now is time to rebuild it
Have you tried swm? Engine is mostly the same,i believe it would take care for most important pieces.
what gasket do you need? I ordered the left and right side case gaskets from my KTM dealer and get them in a few days.
The mechanic said he needs a complete gasket set — which used to be available, but isn’t any more. These are still available: Head gasket. Base gasket. Clutch cover gasket. Ignition cover. Ignition outer. Water pump. But complete sets aren’t. I’ve noticed on eBay some complete sets for older models but none of the suppliers can tell me if they’d work for a 2009.
bottom ends are identical between the 610 and 630. The barrel and cylinder head is different. So all gaskets should work with the exception of the head gasket, valve cover gasket and possibly barrel gasket, tho as you mentioned those are available separately anyways.
Would you know if the complete gasket kits for earlier (2001) TE-610 models are the same as the later models (2009) ? I do see these complete kits on ebay (for earlier models)...
Ok, www.athena.eu has a complete gasket set ... seems that the 2001 version they have will work for later models as well -- at least I visually confirmed the base and head gasket, water pump gasket, etc to the original 2009 part numbers...
