Husqvarna TE 310 2012 idle issue
valteri222
Hello,
I have a few issues with my TE310:
1. When idling the RPM is going up and down a lot. Changes between 2000-3000. Sometimes goes even up to 4000.
2. Bike doesn't start warm. When I crank it long enough it starts but has the rough idle problem.
3. When I put it in gear the RPM rises by 1000
Some notices:
I have reset TPS many times. Its at 102.3% WOT and it goes from 0 to 102.3 smoothly.
COs are 100 102 105. TXC ECU, 12pt injector. I have a small oil leak in the flywheel cover. Problem started after woodruff key sheared, sprag clutch got stuck and fixed that and changed oil.
