Hi everyone! I opened this thread to know if someone could tell me where I can buy clutch discs for my TE 630 (in Europe). I've only found the OEM parts at Italhusky but they are quite expensive (170 €). Also, are they the same of Husqvarna 610 ? Thank you very much!
They should be the same, try crossreferencing part numbers. I happened to have the parts fiche, they are the same as 2006 te-sm 610: 8000 51148 Driven disc 8000 99521 Driving disc It should be safe to assume that they'd fit. Newfren makes decent aftermarket clutch discs, about 90 euros the whole pack I think
Another question on the TE 630 clutch discs: does anyone know if the SWM 650/ SUPERDUAL clutch discs fits on Husqvarna 630? I think so as they have the same engine but the parts numbers don't coincide (Husqvarna: 8000A5259, SWM: 8000A9764). Thank you very much!
Swm and husky part numbers won't match, even if the part is identical. It would be a fair assumption the the clutch plates will fit, but you can only be sure by actually inspecting them.
Yes, i think you're right, maybe i'll write directly to SWM company to eventually verify the compatibility of the swm parts on husqvarna. Thanks! I'm searching some alternatives to the OEM parts because they're very expensive in my opinion (at Italhusky.com the clutch discs set is about 180 euro) but i have problems to find aftermarket products for the TE 630...
Husky-compatible SWM parts have the same part number. If the SWM part number begins or ends with a letter, it is NOT compatible.
