I can't get trip 1 to show anything other than 0.0. I've read the manual over and over. it's tied to the STP 1 function. Press and hold button for 3 seconds, then: 1st step: function ON 2nd step: stop counters 3rd step: reset STP1, TRIP, and AVS data 4th step: activate functions 5th step: stop counters and so on... Not sure what "step" means. Press button again I assume, but that just takes me to the next screen as in regular use, and eventually to Trip 1 reading 0.0. Can't figure out how to make it record anything. The Trip 2 meter works with the above procedure, not Trip 1.
My 630 had the same problem from new. I got a new instrument panel under warranty. I was supposed to replace it myself but still new sitting in the box. Since the bike is no longer under warranty and the gauge unit is unobtanium the solutions are either circuit repair your self or learn to not use "trip 1" or even aftermarket gauges. I just use a GPS and trip 2.
Thanks. So it's not just me. Instrument is mostly unreadable except at a standstill with my head in just the right angle, so it's not a big deal. Could you go through the process of the steps. How do I reset trip 2?
Thanks. And the trip meter starts over automatically. There's no step 4 that you have to do to activate it?
Yes,that one works logically. In mine trip one doesnt work either,i havent bothered to see how it should be activated,one trip meter is enough for me.
