robertk61
The other day I was fitting my JD Jetting 6X and needed to remove the tank to get access to the plug on the injector.
It is easy enough to remove the fuel line/plug off the tank, but there is also a "balance" hose that runs under the frame.
On the left side is a screw type tap and on the right side is a normal twist type tap.
My question is:
Can you just turn off both taps and remove the hose from one side and then remove the tank?
I have a 2010 TE 250 manual and it doesn't have the same setup. (Still haven't seen a 2011 TE manual posed up yet)
Has anyone removed the tank in this way?
Rob.
My question is:
Rob.
