How to convert a brake lever into a clutch lever
Desmoducky
I couldn't find a source for a straight clutch lever fro my 1972 Husqvarna 450CR, so I bought two brake levers in hope of converting one to a clutch lever. Here's how I did it. First, take the brake lever and drill all the way though the cable retaining hole:
Next, weld up the side that had the original hole for the brake and drill the cable retaining hole a little deeper to fully accept the clutch cable retaining cylinder:
Third, grind off the weld WITHOUT touching the original metal surface:
Lastly, polish it to make it sexy and there you go; a new clutch lever converted from a brake lever:
Desmo
if it were mine i would have just drilled both right through . but if that effort makes u happy then goon on ya . the weld matches nice
why all the effort? just turn it over, put the magura lever covers back on and no one will ever know!!!
I did it for two reasons. One, because I could ( no ego trip here).
Second, I wanted a concourse accurate rebuild of this Husky so it had to be an exact match for the original al...
Desmoducky
