Home made press to remove crankshaft from TE450
Tetley
I made a press today to separate the engine casings.
4 layers of 18mm ply drilled out using the alternator gasket as a pattern. 6 lengths of M6 stud, and an M10 stud, nut and washers ground to a piont as the pusher.
It worked perfectly, despite the crank bearing being very tight.WP_20150308_001.jpgWP_20150308_002.jpgWP_20150308_003.jpg
Handy having all that wood just lying there, good way to get around the problem of case splitting.
