I recently resurrected a 73 CR250.  We used to have 2 of them in the 70's.  One was left at a farm for years, where a bunch of kids rode it until they broke it.  I didn't know what the problem was.  But after getting the farm motor running well, (the other motor is seized badly)
I ended up getting it out for a ride. Everything seems to work except, it falls out of gear, when the power isn't applied...and is very difficult to locate neutral at any time.
The shifter just doesn't seem to have that 'positive' feel.
All the gears work, but say, if you are on a trail, and get off the throttle, you will go to hit it again, and the bike is in some kind of neutral state, another bump of the shifter either way, (with the clutch in) will get it into gear. I can take the other motor apart, and use it to replace whatever is broken....what do you think might cause this?
a breakage? or something like a 'bent shift fork', as they say. Any takers on this? Thanks alot.
