Here's a puzzling (fairly advanced) electrical question re a 2011 630
dougn
My brake lites, horn, headlight, and turn indicators stopped working. i figured out they are all on one relay and that relay is not working. the activation coil of that relay is getting power when the key is switched on (there's +12 on the input side of the solenoid). However, the path to ground on the other side of the input coil goes into a pin of the ECU. I can't imagine why it goes in to the ECU instead of just tying to ground. Anyway, that is showing an open circuit so the input side of the relay cannot get energized. Why would that ground path go into the ECU?
The ground is controlled by the ECU. Many ECU's switch grounds instead of power, leaving the relay isolated when it's not connected. I don't have the logic diagram of that ECU, so I can't tell why it wouldn't be switching, my guess is it's not receiving an expected input signal.
Do you have the wiring diagram for it?
I don't have a diagram for the ECU specifically. The fuel pump is not plugged in. Maybe that has something to do with it but it seems unlikely
