KyleGyoung
Hi from vancouver bc! I have just received my previously stolen 610sm back from the police. She got beat up pretty good but everything should be in good mechanical order!
I can get it to crank all day no problem but not a spark! Please help me identify the electrical component that's acting up..
It has a fresh car battery for testing. 12.8v
I opened it up and the magnets are still in their positions, some glue has flaked off.
I read 98ohms on the green-white at the stator to cdi clip. I believe this is the pickup coil which should be 100ohms
And 247ohms between red-black I think this is the exciter coil. I can't find the spec on this tho.
When cranking I put my meter AC on the spark plug and get small rhytmic deflection, less than 1v though.
This brings me to believe some trigger power is being Sent from the cdi? So the spark coil is weak? It was within spec from the husky manual.
Any other ideas would be awesome guys, I don't want to start buying expensive parts before I can pinpoint it.
Thank you all so much
