MorrisBetter
My 08 TE510 started blowing the main fuse (on top of the starter relay). I've recently added the Trail Tech DOT headlight kit, as well as a powered GPS mount.
I've looked at the wiring and everything looks kosher. I dressed the wiring behind the headlight to make more room, and I don't think there's a problem there.
The fuse blows when I press the starter button. The new headlight must draw more current that the stock unit. Could the light add enough current to blow the fuse.
I also saw an error code on the display, but it went away before I could read it.
I'll check the schematics when I get home, but I wanted to get this message posted up ASAP.
