rocko
I plan on changing my gearing but not sure which route I want to take.
If I understand correctly, going down one tooth on the front sprocket is about the same as going up 3 in the rear.
Which do you recommend? Up three on the back? Down one on the front? Something else?
I plan to ride 75 percent street, 25 percent track.
I thought of some pros/cons of each, let me know if you agree:
Down one on the front:
Pros - cheaper part, and don't have to get a longer chain
Cons - Smaller radius on front sprocket may increase chain wear, harder to install
Up three in the back:
Pros - easier to install than front, doesn't increase chain wear
Cons - more unsprung weight, may need longer chain, more expensive part
Thanks for any info!
