Fork oil leak
mikedbike2002
My 2006 Husky SMR510 is leaking fork oil from the junction of the fork tube & the bottm bracket that mounts the caliper & axle. Anyone run into this before & does anyone know a fix. It s leaking 360 degrees around the red area in the photo. HELP,HELP!fork leak.jpg
Wow, thats pretty rare as far as I have seen. But, believe it or not, the stanchion tubes are threaded into the foot and usually bonded with RED Loctite (or similar). Get the stanchion nice and clean so you can get some good grip on it (rubber gloves might help too) and give it a twist to see if you can get it to move. If you can, it would be wise to pull the forks apart and re-do that joint (or have it done). If it doesn't twist, could be a bad or missing seal in the foot (or even a cracked stanchion) all of which will require heat and torque to remove the foot to repair.
It could be leaking there, but more likely its leaking from the seal, running down the tube where you cant see it and resting on that spot. If im wrong, your 1 in a million.
If im right, pull down the wiper, clean the seal with a business card and pack between the seal and wiper with grease and put it back together. Push down on the forks a buncha times cause the grease will track on the tubes for a bit and clean it off.
Wrong! No seal leak!I removed the fork tube from the bike & took it completely apart. I took the bottom off by removing the small allen bolt that keeps the fork tube from turning.Gently heated up the lower bracket as it was in the vise & then unscrewd the fork tube. Wired brushed all threads, cleaned both up with carb cleaner. Then put a ton of Super Glue on the threads,screwed it back together & let it sit over night. In the morning reassembled the fork & put back on the bike. NO MORE LEAKY!!!
