Fixed My Starting Problem
huskyista
Well, she starts fine now. Had a clicking sound coming from the starter relay, but no power to the starter and no crank. So, I got a new starter relay. Now, upon removal, I found that where the positive battery cable connects to the starter relay, it was dirty and burnt. Most likely that was the problem all along. I replaced the relay and used dielectric grease on the connections. I kept the old relay. The bike starts and runs better than it did before. The electrical system pulls a lot of current through the battery connection on the starter relay. It needs to be kept clean. Dielectric grease helps.
Probably a dumb question but; if I'm going to use that dielectric grase on the gang connectors, do I have to be real careful not to have the grease cross over between connections and cause problems that way? Since the grease helps conduct, couldn't that cause a short or something....?
Well, that just shows my ignorance:o . Does that mean other "regular" greases could conduct and that's why you shouldn't use them? (like Bel-ray waterproof grease-that I have on hand)
