First valve check. .25mm and .18mm. Should I shim?
AndrewS
I did my first valve check at about 250km. One exhaust valve is at .25mm and one intake is at .18mm. The other two valves are within spec.
Should I shim them both? Reading other threads, it sounds like they tend to tighten over time. I'm not sure how much is reasonable to expect them to change, given that others have had them not move at all.
Also, I'm guessing I should shim them to the upper limit (i.e. .20mm and .15mm) with the expectation that they'll tighten up?
I think I would go ahead and shim them because I dont think they will move much more and I doubt they will move enough to put them in spec. I have about 100hrs on mine and shimmed it once at about 20hrs and they havent moved since.
It's been a busy day, and honestly not everyone thinks in metric :doh:
So I dug out my manual... for my 2006 TE250...
Intake: 0.004 to 0.006", or 0.10 to 0.15mm
Exhaust: 0.006 to 0.008", or 0.15 to 0.20mm
The shims come in increments of 0.002", or 0.05mm
So the exhaust is too loose by 1 shim size, and changing 2 sizes would make it on the tight end of spec.
Changing that intake by 1 shim size would you perfectly in spec.
If it were me, I would seek out the different shim sizes to be in spec. As slow as the valves move, compared to other brands, I really would not worry about loose vs tight end of spec too much.
I certainly would not miss an opportunity to go on a ride with the valves the way they are now though. :)
Looks like shimming is the way to go. Thanks both for the responses.
Dean, you anticipated my next question... that I can ride in the meantime. :)
You could spend the time shimming, but if it was my bike, I'd leave it and go riding.
Being a bit too loose(ie. .001 or .002") won't hurt anything & they're going to tighten up over time anyways.
If they were loose by a bunch, more than say.010", then it would start to affect power output and would be a bit hard on the valvetrain.
