Factory Bent Frame
1982 XC 430
1984 WR Frame ( the last of the Air Cooled 250's ) very low hour bike with original Tires. I assume that the front Down Tube is bent from the Factory, to allow the Exhaust to clear. I see no dents or other damage to suggest this happened in the short life this bike was ridden.
They did that, I don't think they did it for the four stroke, not sure about the 125. You are quite fortunate,should be a long time before you see metal pieces of much size on the magnet.
Yes, the frame down tubes were made that way to clear the exhaust on air cooled. Same thing on my 83 500CR.
I had the same scare as you . Coming off an 82 430 XC restoration I moved to my first white bike 84 resto of the fantabulous 240 WR and thought I had a bent frame. Couldn't figure out how the frame was bent but the bike had zero evidence of a smack up. Once I noticed the asymmetric engine mounts all was well!
The 4 stroke has the frame simmetric.
I will post some pics soon to compare the difference immediately.
All of the 83/84 Air cooled 2t frames are more or less the same. Differences between the Enduro / XC frames and the CR frame is the rear loop and the under motor guard rail and sometimes a steering lock and floating or non floating rear brake setup.
The Aircooled 510 frames have a straight front down tube and a dent in the right side lower frame rail to miss the bigger ignition flywheel.
Andy.
