58Driver
A little background:
2011 TXC 511
I went on a dual sport adventure a few weeks ago and ended up on the side of the trail from the coil ground on the side of the head.
reference:
http://www.cafehusky.com/threads/449-511-ignition-ground.28115/page-2#post-258103
I stripped the broken ground wire and tightened the bare wire back on the head to get home.
The bike ran mostly good but would randomly sputter.
Friday, I serviced the bike and added a 12ga wire spliced to the black coil ground wire and ran it to the back of the motor where Londin Suggested in the above post. I also replaced the plug with a CR9EIX, accepted my PCV trims and opened up the airbox TC style.
Sunday left on a super twisty supermoto ride. I rode about 60 miles and stopped for gas. The bike has never run this strong. I was stopped for about 20 mins total.
I left out again, and now im getting the random sputter again like a bad ground. It got a little worse, and then died altogether. This time there was no roadside remedy and a long walk followed.
I took enough stuff apart last night to verify that there is in fact no spark at all.
The plug still looks brand new.
My local Husky dealer only works on the xlites and soes not have any diagnostics or experience with the 449/511.
My list to troubleshoot / eliminate so far is:
Kill switch - Is there a place to check for ground in the wiring harness to verify if the kill switch is activated? I can just take it apart too.
Coil - It seems like there hasn't been a documented failure of this part, but if it didn't work with an average ground, then maybe it was starting to fail?
Plug that connects to coil - Is this replaceable? its not in the parts list. it only has 3 very short leads.
Ignition pulse to coil - I think this comes in on the red wire going to the coil, I don't know how to measure it.
Im open to any advice / troubleshooting tips I own a multimeter, but im far from an expert on this stuff
Thanks in advance, Dave
2011 TXC 511
reference:
