Dash Problem
hasenpfeffer
Over the past couple years my bike has been having dashboard problems. The bike starts every time and runs great. The dash, however, will intermittently stop working while riding. The backlight, turn signals, status lights, and tachometer stop working. It may do this for short periods, or long. I have not been able to reproduce the problem directly, making it difficult to diagnose. I have checked fuses. I have checked power and ground connections at the dash connector, pins 12-14. All look good. I have a brand new battery. I don’t yet see any poor wiring or other indications of bad connections. I do have the full workshop manual and wiring diagram. Does anyone have any recommendations what else to look at?
Carefully remove & separate the 2 halves of the dash. This will give you access to the PCB where you can check for water damage.
I’ve been avoiding taking that step so far. Hoping someone else may have encountered this behavior and maybe has a bit more specific cause they’ve found?
Disassembled the dashboard. I found it to be in nearly perfect condition, with no signs of moisture intrusion. The only problem I found is the bottom case half screw mounting posts are all cracked. These are causing the white plastic and board mounting screws to be loose. But nothing really pointing to my problem.
Try to Replace your rectifier regulator with a known good one. Voltage spikes trigger cluster shutdown to protect pcb components.
