WrestleMania
Esteemed fellow riders -
Parts fiche calls for a #180 main jet and #50 idle jet. My 2007 Husky TE450 has these, however it is experiencing the issues below. Am I misreading the fiche? Could it be an electrical problem? What's your opinion?
Symptoms:
Symptoms:
- Starts easy and runs well cold
- Runs rich, smells rich, atrocious gas mileage
- When hot, chopping the throttle stalls the engine
- Also stalls easily in low RPM conditions (tight trails, etc.)
- Idle does not change when adjusting mixture screw
- Disassembled FCR carburetor. Very clean inside
Cleaned all parts again.
- Checked for aftermarket jets. They are factory afaik (#180, #50).
- Carb diaphragm base plate was warped due to over-tightening. Replaced both diaphragm and base plate, squirts like a snake now.
- Carb floats were set high. Adjusted to lower setting.
- Needle clip set to 5. Changed to 4.
- JB welded a superficial crack in the main jet housing
