Clutch Question
towpro
I did my first "hard core rock ride" on the 08 TE 250 today. I have the uprate kit but I was running the O2 sensor. I have 1 tooth larger on the front sprocket.
Riding it like a tractor around 3000-3500 RPM in 3rd gear worked great. Very little wheel spin with my pirelli trials tires, they performed flawlessly on the wet slimy rocks and roots
. Come to an open section, run up the RPM and it takes off with more then enough power for what I am doing. It dragged my 240 lbs around the woods with no problems.
Before we left The guys I was riding with looked at my tires and had that look "it going to be a long day waiting for this guy" but once they saw how well they worked they are thinking about trying them.
Anyway, once I had been riding an hour or so it became very hard to find Neutral. It felt like the Clutch was not disengaging all the way. Plus when you were in Neutral, pulled in the clutch and kicked it in gear it would grind just a little. It only does it Hot. Anybody got a quick "how to" on any internal adjustments to the clutch system?
I plan on picking up some mineral oil to flush out the system.
On a site note, I do wish the bike was a little quieter though. If I was running higher RPM I would want to wear ear protection with this one. The Arrow seems just as loud as the stock pipe so I run the Arrow for the weight loss.
