Check the Fuel Pump
Sam
HI,
first sorry for my bad english I´m from germany
I have a problem with my TE310`09, my dealer and I thinks the Fuel Pump (the pump wer is in the tank) don`t work the hole time so we think.
Do you know can I check the pump if it works normaly?
The Problem from the TE310 is that i have sometimes not the full power. It´s hard to describe it in englisch
Thanks Thomas
Guten TAG!
The dealer should know how to test the pump... I can't describe it accurately and it won't translate well enough for sure if I tried- but its in the Manual. Tell your dealer to spend the $10 and buy one! That's what they tell us (ok That sounds bad.... but its true!) PM ME your email and I'll send the test
You only hear the pump- when it primes initially. I would think if the bike runs just not as well as you like- its more of a problem with settings and set up- Pumps run or they don't run- they usually don't sometimes run.
:thumbsup:
Hi Thomas,
The pump can fail and I have seen afew do this!
With the Aprilia they blow a fuse and die, on the husky they seem to keep going but run really bad.
The bike runs poorly and may not start easily unless you turn on/off a number of times to prime the pump over before hitting the start button. Its as if it isn't putting enough pressure into the fuel line from one cycle when priming (the whirr of the pump).
Try a tank from another bike on it to establish if the fault is with the pump.
brock
09 TE510 UK
