Chain Size for 50t Sprocket?
Nick McCabe
Looking to order a 50t sprocket for my 14' TE310r. I have the stock 13-40 set up now and am just changing the rear. Should I order a 120 link chain, or something larger? Or, can I just add a couple links to the one I have now? If so, how? Also, any tips on where to get a low priced sprocket, not concerned with it lasting forever, mostly price.
Get a 120. You will remove a few links. I just instinctually went here for chain and rear sprocket... http://dirttricks.com/. Dealers have the stock sprockets for not very much. Check Bills too as got my countershaft sprocket from him..
Lived in Victorville for 14 yrs before , El mirage is a fun place to ride , I do mostly adventure riding nothing really narly so I just kept my stalk sprockets on cause I have to get on the highway at times and I can hit 60 or 65 easy at only around 7500 rpms but don't ride that speed for periods , for your riding 50 teeth sounds good .
I thought I would be fine with it but the problem is in 1st gear to have any power I need to be going like 12-15 mph. On these steep trails I'm doing more clutch slipping than I want to, takes some enjoyment out of it.
Probably 100 according to gearing commander. Revs are comfortable at 45 and get real busy above that. Short bursts to redline, OK but I am not sustaining them with the tiny sump.
